Microsoft mpeg4 v 2 on a Mac?
Luke Hale
on Nov 29, 2007 at 2:36:37 am
Is there a way I can encode video in Microsoft mpeg4 v2 on a Mac? If not, what is the best way to encode in that exact format?
Thanks a lot,
Luke
Craig Seeman
Re: Microsoft mpeg4 v 2 on a Mac?
on Nov 29, 2007 at 4:27:01 pm
While Flip4Mac can certainly play back that codec on the Mac, I can't even FATHOM why you'd want to encode to MPEG4v2. Is this for playback on antique computers?
Heck I don't even think Windows Media Encoder on Windows encodes anything older than WMV7
Even Windows Media Player 7.1 can play back Windows Media Video 9 files. WMP7.1 works on nearly 10 year old Windows 98. If someone hasn't moved beyond WM98 SE then I'd either get them an OS upgrade or a new computer.
Luke Hale
on Dec 2, 2007 at 8:42:43 pm
It's for playback on a photobooth, basically a demonstration video that will play when it is not in use. Apparently MPEG4 v2 is the only format that will play on the device. Is there maybe a modern, similar equivalent that might work? I have tried Flip4Mac and it's no good. Any other suggestions greatly appreciated!
Luke
Luke Hale
Re: Microsoft mpeg4 v 2 on a Mac SOLUTION
on Dec 2, 2007 at 9:27:26 pm
Just in case anyone ever has the same problem, I used a piece of software called Video Converter for Mac, http://www.mp4converter.net/video-converter-mac.html, to encode to Mpeg4 v2. Problem solved!
Craig Seeman
on Dec 2, 2007 at 9:50:38 pm
Nowhere does it show support for Mpeg4v2
See this article
http://en.wikipedia.org/wiki/Windows_Media_Video
and see this when you scroll down
Microsoft MPEG-4 Video Codec V2 MP42 Video for Windows-based codec. Non-standard MPEG-4 codec incompatible with the later standardized version of MPEG-4.
Luke Hale
on Dec 2, 2007 at 11:25:03 pm
Umm, I realise it may not show support for the codec, but I did just use the program and encoded MS mpeg4 v2 successfully. It may seem suprising but it definately does work.
Danny2007
on Dec 6, 2007 at 11:55:09 am
Maybe it's using this somehow?
http://homepage.mac.com/hmason/mac-ms-mpeg4v2/
