uncompressed avi or animation quicktime
AlphaChannel
on Nov 29, 2007 at 2:02:13 am
What's the consensus on the best format to render to on the PC, as an uncompressed .avi file or a quicktime using the animation codec set to best quality. I've always created quicktimes but until recently I've only used Macs. Or does it even matter?
Evil Ash Editor
Re: uncompressed avi or animation quicktime
on Nov 29, 2007 at 2:28:42 am
Where are you planning on taking the file once it's rendered? If you're bringing it into an Avid, you might want to go with a quicktime file render with an Avid 1:1 or Packed Codec (1:1 10 bit).
Depending on where you want to do with the video might make a difference which codec will suit you best.
Richard Sanchez
North Hollywood, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
Danny2007
on Nov 29, 2007 at 11:09:47 am
The problem with AVI is that it's just a container for audio and video. It's not always possible to know exactly what is contained as such it's not always cross platform.
The advantage of Quicktime Animation is that it's a known, it's 4:4:4, it cross platform and any setup with Quicktime installed will be able to work with the file.
Animation is only lossless when set to 100%
