Encoding PAL for DVD using Apple Compressor
BklynHunger
on Nov 14, 2007 at 9:09:31 pm
Hello
I am looking to get some advice on encoding footage from a PAL BETACAM SP tape (from an Avid Adrenaline) - ultimately to then encode using Compressor for DVD (both NTSC & PAL format)
I need to compress for DVD in PAL & NTSC and again the footage is from a 90 minute BETACAM SP tape onto the Avid Adrenaline. I have only ever done NTSC so this fottage with be in PAL when i bring it into Compressor.
The Senior editor has a pretty busy schedule during the day but is ok with me doing this personal project after hours - I just want to make sure i set it all up properly.
I have never done anything PAL or BETASP on this deck and Avid Adrenaline so I am hoping you guys can tell me everything I need to know about setting up Compressor to encode both a PAL and NTSC set of MPEG2 & AAC.
Any help would be greatly appreciated. Thank you
BKYLN
