black levels with dg fastchannel
Bmoneymedia
on Nov 9, 2007 at 7:58:13 pm
It's sad to see, but refreshing at the same time to see that I'm not the only one havign issues with DG. For a while i though i was just a novice idiot. Well, i guess the novice part is still true.
Is there settings within Episode that i can use to ensure proper black levels during my compression to mpeg2? Or should this be something I try to correct with After Effect Broadcast Filter? Or am I off on both?
Fred Connors Jr
Re: black levels with dg fastchannel
on Nov 10, 2007 at 4:59:42 pm
B
You cannot compensate with the filters in Episode.
We do it with FinalCut Pro, I am sure you can do it with AE.
http://forums.creativecow.net/readpost/20/858459
Fred
The Troupe - Modern Media Design & Production
