pls help with ftp compression
Zeliha
on Oct 25, 2007 at 12:49:13 pm
Hi All
I work for a post house and we often need to FTP the programmes to the relevant channels.
Programmes are edited with FCP 5 using DVC PRO-HD 29.97 codec (7.6MBpsec.)
Programmes average 1 hour and need to be delivered in MOV or WMV format - 150MB max file size and 320x180 min. dimensions.
What is the best way I can get this exported and delivered as quickly as possible?
Zee.
Danny2007
Re: pls help with ftp compression
on Oct 25, 2007 at 7:07:02 pm
Without splitting that clip up, I suggest that you go for low bitrate MPEG-4. Your total data rate NEEDS to be under 250Kb/s to be under 150MB total.
