The Age Old Question- Episode, Sorensen, or Cleaner?
Jason Griffith
on Oct 1, 2007 at 7:27:37 pm
Ok guys,
I'm venturing into the online video world. And on my quest, I have come to the decision crossroad of which compression software to purchase. I have done some research on H264 and the On2 VP6 codec. I'm going to be uploading Documentary clips that could push the 20 minute mark with some fast moving scenes. I haven't decided on the codec yet and more importantly, the software package to compress it with. So her I am to consult with those in the know. Which road should I be traveling down? I'm running on a Mac with OSX
Thanks for any help in advance,
Jason Griffith
organicpixels.net
"An Unexamined Life Is Not Worth Living" - Socrates
JackHammer
Re: The Age Old Question- Episode, Sorensen, or Cleaner?
on Oct 2, 2007 at 9:43:53 am
My vote goes to Episode, I love cleaner but it's so unloved by Autodesk and as such has been left behind in the performance stakes.
David Roth Weiss
on Oct 3, 2007 at 1:36:24 am
I think the answer really depends on the format you choose for delivery. If you choose Flash for example, there's no reason to buy a $600 Swiss Army Knife to encode it, when Flix Pro will do the job as well or better for $249. If you choose to go with h.264 you might be able to "Squeeze" a better file out (pun intended) using Sorenson or Episode, but compressor and QT Pro do a pretty decent job. So again, why buy the expensive Swiss Army Knife unless you really need it?
I also say forget Cleaner... Discreet and now AutoDesk have never kept that product up to date.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los Angeles
POST-PRODUCTION WITHOUT THE USUAL INSANITY™
A forum host of Creative COW's Business & Marketing, and Indie Film & Documentary forums.
Victoria Hansen
Sorensen advice
on Dec 10, 2008 at 3:20:06 am
Hi David,
I came upon your reply while searching for compression software. I have Sorensen Squeeze, but regrettably know little about it. I have successfully compressed audio and video files, but have some TV segments I did on a regional network here in Australia that I want to upload as flash on my website http://www.bitesizecooking.com Problem is, using 'sml prog' swf, I still can't get these small enough for the site. My programmers have told me to try to get them around 5mg if possible. A friend who is an editor mentioned one might be able to set a compression limit for the file, but I don't know enough about the software to do that. Can this be done with Sorensen and if so, how, and if not, can you recommend another easy to use compression software I can use. I'm relatively web and computer savvy but not editing savvy.
regards
Victoria
victoria@victoriahansen.com
Craig Seeman
on Oct 3, 2007 at 11:17:27 pm
I think Swiss Army knives give maximum flexibility.
Episode is fastest for everything at the moment. It's great for VP6.
Compressor is great for H.264 but multipass encodes will take a long time. ON2/Flix may well have a VP6 plugin that will work in Compressor but haven't looked at that option. BTW Episode comes with a plugin for Compressor 3 now! Best of both worlds with that.
Squeeze is very easy to use but doesn't have the processing filter control that Episode has. It's a nice programe though.
Cleaner is SLOOW and Autdesk provides very little support. If you run into a bug with Cleaner don't expect a bug fix for a long time if ever. It's the only one I'd list as a must to avoid.
BTW, I have and use ALL of the above (except Flix).
Jim_Gunn
on Oct 8, 2007 at 3:32:03 am
I do a LOT of video encoding from Dv and hdv sources and I have been using Cleaner XL (now ver 1.5) for pc for years. It does a great job with batch video encoding to multile formats and has sophisticated controls including color correction and audio filters and many other things.
I have also used the latest version of Sorenson Squeeze (4.5) and it has a somewhat friendlier interface than Cleaner XL and encodes much faster, especially for Flash video which it handles beautifully. However one major thing Squeeze lacks is the ability to add a watermark to the finished videos during the encoding process like Cleaber XL can. That is a major flaw and that is the main reason that I still use Cleaner XL 1.5 to encode to WMV, Quicktime, Real and other formats for my clients.
Craig Seeman
on Oct 8, 2007 at 3:39:50 am
Episode also does watermarks and even burn in time code.
Jason Griffith
on Oct 12, 2007 at 9:18:04 pm
Ok guys,
I think I'm going to go with Episode. It's more expensive than the other options, but then again, this is my product and it needs to look great. Not to mention I will be compressing hundreds of 10-15 minute clips. I need the speed.
Jason
