FC6->Episode->DVDSP4 bitrate problem
griffeyt53
on Sep 24, 2007 at 6:08:31 pm
I'm receiving a bitrate too high message from DVDSP4 only from Episode encoded files. (Occurs on more than one exported sequence) Here's the workflow...
HDV 1080i sequence in FCP6 exported as QT movie - ProRes
Compressed using Episode using following settings starting with the HD->SD 6mbit preset...
Bitrate-based, peak rate 7000 and avg 6000
4:2:0 color space with 16:9 ratio, Progressive encode type and field order "same as input"
2-pass and other MPEG-2 settings default
Resize filter on - 720 X 480
Import asset into DVDSP and see average bit rate is 6.1 Mb. When building I get the "video bitrate too high". When encoding in Compressor 3 using the 90-minute BEST preset (a peak of 7.2), the average bit rate for the file is 6.3 Mb and DON'T get the bitrate too high error.
I also notice that DVDSP reports the asset as 29.97 non-drop with the Episode encoded file and 29.97 drop with the Compressor encoded file. This may mean nothing.
Is Episode missing bitrate spikes?
Thanks for your help.
TG
