Preferred frame sizes and compression format for exhibition display?
Mike_S
on Sep 7, 2007 at 10:13:08 am
Any thoughts / experience on this?
The display to be on big a plasma screen - I don't have a spec on that yet, and obviously need it.
Playback is likely to be from a laptop so I guess there's a wide choice of formats.
If the plasma supports HD, is it worth using an HD format (material will be largely animated graphics and still photos I think)? Or does the relatively large distance people will typically be viewing from mean that upscaled DVD-quality would look as good ..?
If HD, any thoughts on 1080p vs 720p, choice between QT and wmv - or other formats ..?
Rich Rubasch
Re: Preferred frame sizes and compression format for exhibition display?
on Sep 11, 2007 at 1:50:17 am
If it's a Mac laptop I would go with progressive 30p H.264. You also don't specify how you will edit the material...is it on a Mac or a PC? More info on your workflow might help us make a stronger suggestion.
Rich Rubasch
Tilt Media
