Compress to very small file
Logan5
on Aug 7, 2007 at 2:20:15 pm
I have a 52 second video clip that I need to compress to an .mpg that is 2megs or less. I can't seem to get it under 3megs. Any suggestions?
The clip was edited in FCP and I'm using Compressor 3.0.1.
Thanks.
Rich Rubasch
Re: Compress to very small file
on Aug 7, 2007 at 4:47:34 pm
Are you looking for an MPEG-1 or an MPEG-2 file? Or an MPEG-4?
What are your current settings?
Rich Rubasch
Tilt Media
Logan5
on Aug 8, 2007 at 2:04:00 pm
It needs to be an MPEG-1 file. I'm not sure what you mean by my current settings. I have made about 20 files with different setting and can't get it below about 4.5MB. I have even varied the file type and size when exporting from FCP so I start out with a smaller file in Compressor.
I am new to Compressor but have changed about every setting I could think of to reduce the file size with no luck.
Thanks for replying to my request. Hopefully this added info will help you help me.
Danny2007
on Aug 8, 2007 at 3:05:48 pm
I don't use compressor anymore but I've used Episode to create a bunch of 1 minute MPEG-1 clips that came in at about 2.4MB.
Settings:
Video
192x144
25fps
250kbit/s
Audio
32kbit/s
Mono
22050Hz
They didn't look 'too' bad either ;-)
Ben Waggoner
on Aug 8, 2007 at 3:53:37 pm
That'd work.
2 MB in 53 seconds requires
(2 MB * 8000 Kb/MB)/53 sec = 301 Kbps
My compression blog: http://on10.net/blogs/benwagg/
My compression class at Stanford: http://digitalmediaacademy.org/courses/video-compression-training.html
Logan5
on Aug 8, 2007 at 4:06:56 pm
Thank you for all your posts. However, I still don't think my question has been answered.
How do I do it????
I understand how it works mathematically. But when it comes to actually making the file in Compressor, how do I do it? What settings do I need? I have reduced everything to the smallest setting I can find but still end up with a 4.6MB file.
Danny2007
on Aug 8, 2007 at 8:28:07 pm
Can you supply us with a detailed run down of what settings you have now that give you the 4.6MB file?
Logan5
on Aug 8, 2007 at 8:55:34 pm
Starting with an .mov file exported from FCP.
Placed into Compressor v3.0.1
Dragged and dropped MPEG-1 setting from MPEG-1 preset folder
In the Inspector I changed from DVD to Web and reduced Bit Rate to 0.50 (the lowest it will go)
That is all the settings that I can change (except for Cropping which I don't want to change).
Back at the Inspector Summary it tells me that the Estimated file size is 4.44MB
Here are the other settings displayed in case it helps:
File Extension: mpg
Audio Encoder:
Format: MPEG
Sample Rate: 48 kHz
Channels 2
Bits Per Samle: 16
Video Encoder:
Format: MPEG1
Width and Height: Automatic
Selected: 320 x 240 (I was unable to change this setting)
Pixel aspect ratio: Square
Crop: None
Padding: None
Frame rate: (100% of source)
Selected 29.97
Frame Controls: Automatically selected: Off
Danny2007
on Aug 9, 2007 at 7:42:21 am
Looks like you've hit one of the limitations of compressor; if you can get the frames size set to smaller than 320x240 and the datarate to lower than 0.50(?) then you'll not get the file sizes you need.
An investment in Episode is a good investment. As far as I'm concerned it's a far more capable encoder.
Logan5
on Aug 9, 2007 at 1:36:39 pm
Thank you for your help.
