Interlacing issue DV NTSC
Tippytink
on Jul 24, 2007 at 10:46:19 pm
I haven't been working with DV footage for a couple years. I seem to have forgotten how to deal with interlacing issues when burning DV footage to DVD from FCP. I shouldn't be too hard since it is so common. Please help jog my memory on how I used to deal with this. I am exporting using Compressor from FCP bottom field first. Do I really need to add a filter or wait hours for a frame controled compressor export?
Thanks.
Melissa
Ben Waggoner
Re: Interlacing issue DV NTSC
on Jul 26, 2007 at 12:31:39 am
You shouldn't need to do anything at all. If you'r using a tool that lets you, just set the MPEG-2 field order to Bottom.
My compression blog: http://on10.net/blogs/benwagg/
My compression class at Stanford: http://digitalmediaacademy.org/courses/video-compression-training.html
tippytink
on Jul 28, 2007 at 12:44:18 am
I realized that their problem was that the timeline used to be anamorphic and therefore the titles were still anamophic... which was making the titles look horrible... which made me think I was doing something wrong. All is well now that the titles are fixed. Thank you very much for your response.
Melissa
