Can't cancel a job in batch monitor
ihavefriends
on Jul 16, 2007 at 8:54:58 pm
Something went horribly awry during an export out of compressor (the job progress got stuck) , and I've decided to re-submit my batch. The problem is that I can neither pause nor cancel the current stuck job in the batch monitor. I can add as many jobs as I want to the queue, but it's been "cancelling" for about half an hour. Any help is appreciated, thanks for your time.
Danny2007
Re: Can't cancel a job in batch monitor
on Jul 17, 2007 at 4:22:24 pm
Force the application to quit - right-click (CTRL-click) on its dock icon
timebombtim
on Jul 17, 2007 at 9:05:47 pm
wait it out, or foce quit and restart, pick up from the last successful file. best i can do.
peace
ihavefriends
on Jul 17, 2007 at 9:41:43 pm
Thanks for the replies I had tried quitting and restarting (was able to do both) but everytime I opened compressor the job would just start back up again in a frozen state. Funny enough just after I posted I found a clear queue button and was able to re-submit and be on my way. Thanks again for the time though.
cowcowcowcowcow
johatk
on Aug 8, 2007 at 12:34:48 pm
None of this worked for me. Even turning off the whole computer did not remove the file from the Batch folder. Here's a solution I found on the Apple support site...and it works.
1. In Finder select go, go to folder
2. Enter: var/spool/qmaster
3. This will find a folder (oddly named with numeral & text). Trash the folders you see INside this folder (mine were called Shared & Jobs
4. In compressor, select the menu item Compressor/reset Background Processing.
John.
Robert Gillmer
on May 18, 2008 at 5:18:49 pm
[johatk] "2. Enter: var/spool/qmaster"
It's actually " /var/spool/qmaster " and thank you very much, I had the same problem.
Elijah Lynn
on Jul 30, 2008 at 3:33:13 pm
I have two folders in my /var/spool/qmaster/ I guess I will delete contents in both.
Brand new mac pro 8 core with FCS and been having a ton of compressor issues.
Keith Golinski
on Jun 2, 2009 at 7:06:37 pm
Great Post! Thank you.
I had the same issue. Bad design.
Fabian Hannaert
on Mar 21, 2010 at 9:25:16 pm
a million thanks! it worked for me too.
hope holmesby
on Jul 28, 2009 at 2:27:42 am
where did you find a button in batch monitor that says clear queue?
John Atkins
on Jul 28, 2009 at 2:42:43 am
Here is a free utility that may help.
http://www.digitalrebellion.com/compressor_repair.htm
John.
Elijah Lynn
on Jul 30, 2010 at 1:40:11 am
Thanks John, I deleted the folders in /var/spool/qmaster and reset background processing but no cigar, I downloaded compressor repair and it finally got rid of them.
El Earthbourne
on Nov 1, 2011 at 5:23:25 pm
Thanks! Great post. Compressor repair program is super!
