400x300 - FLV - Not right?
Danny2007
on Jul 9, 2007 at 11:36:53 am
Guys
I have generally always avoided encoding to 400x300 as I don't believe it's a correct frame size, i.e not divisible by 8.
I'd rather opt for either 384x288 or 416x312.
That's said I see some many clips delivered at 400x300.
In this instance I'm specifically referring to Flash encoding (VP6)
I'd love to hear the opinions as to whether divisible by 8 is a big deal when it comes quality and efficiency, or not.
Danny
Evil Ash Editor
Re: 400x300 - FLV - Not right?
on Jul 10, 2007 at 6:48:36 pm
I have actually encoded to 400x300 and not noticed an issues with it. I would recommend testing it out on your footage. Also, if you're concerned with it distorting your picture, encode a video of a circle to see if the frame causes it to become elliptical.
Danny2007
on Jul 11, 2007 at 10:45:30 am
Err nothing to do with PAR or frame aspect ratio (400x300 is quite obviously 4:3) but absolutely to do with what I thought were some of the basics of compression i.e. adhearing to a frame size divisable by 8x8 (or 16x16) macroblocks.
I've done my own tests and can see a difference between a non-div 8 frame size and a div 8 frame size. I just want to better understand why so many seem to be ignoring the fundimentals.
DL
yuzztme
on Oct 13, 2007 at 9:47:06 pm
I've been looking for an answer whether to use a frame width/height value which is a multiple of 8 or 16 pixels. The VP6 codec doesn't seem to have any restrictions regarding framesize. I did find out that frame width/height values are not only codec related, but also depend on the used color space.
For FLV I use the YV12 color space. Both image dimensions have to be a multiple of two, if the video is interlaced the height has to be a multiple of four.
Danny2007
on Oct 14, 2007 at 9:06:22 am
I'm not sure where you've got your information from but I disagree with it.
According to On2, the makers of the VP6 CODEC used in Flash video, the frame size should ideally be equally divisible by 8 on both axis, as outlined on this page:
http://www.on2.com/support-resources/flix-tutorials/flashvideoquality/
The same can be said of pretty well all video CODECS out there, usually however it should be 16 rather than 8. Certainly not 2 or 4.
I don't understand your reference to YV12 and, did you mean YV12 as your source? - FLV is an RGB CODEC.
Lastly FLV is a progressive only format, you should deinterlace interlaced source before transcoding to FLV.
JackHammer
on Oct 15, 2007 at 9:11:05 am
Danny2007 is right - frame sizes should be divisible by 8 or 16.
Here's a list of optimum sizes: http://blog.influxis.com/influxis/?p=14
