How to tell if m2v file is top first or bottom first
worldofjeff
on Jun 30, 2007 at 7:08:33 pm
I've got some m2v files that were encoded using Compressor. Is there a quick way to check if they were encoded with Top First or Bottom First? I want to double-check that they were encoded correctly, and if there's a quick way to tell without having to burn some tests first, it would save me a whole lot of time.
-Jeff
Ben Waggoner
Re: How to tell if m2v file is top first or bottom first
on Jul 2, 2007 at 12:22:05 am
BitRate Viewer will tell what the file is flagged at.
However, that won't tell you if the file was flagged correctly in the first place. I generally wind up taking it into After Effects and dropping it onto a 60p timeline, and seeing which field order gives me correct motion.
My compression blog: http://on10.net/blogs/benwagg/
My compression class at Stanford: http://digitalmediaacademy.org/courses/video-compression-training.html
