I need High quality VCDs and DVDs
funnyfriendbilu
on Jun 30, 2007 at 1:11:22 am
How could i get High quality VCDs and DVDs from Avid Xprs Pro and Adobe Premier?I used Canopus Pro coder 2 with default 'Mastering Quality'.But I am not satisfied...There is any other program do better than Procoder2 or Procoder2 need any other tweaking?Please some one tell me...
Danny2007
Re: I need High quality VCDs and DVDs
on Jul 2, 2007 at 7:23:29 am
IMHO there is little out there, at this end of the market, better than Procoder 'mastering quality'. How good is your source?
hipstone
on Jul 16, 2007 at 12:31:05 am
I Procoder you should have the option of tweaking up the bit rate. I agree that this is the best encoder at this end of the market.
Make sure you use "MASTERING Quality" 8100kbs at CBR with a PCM soundtrack. On a single DVD-R you will have a limit of about 64 minutes (or less).
If you need more time on the disc, go to AC3 for audio, and drop the bitrate to something less than 8100, like 7300kbs.
Keep in mind top quality limits your running time to just over an hour imo.
