pillarboxing 4:3 when exporting to 16.9
cowcowcow
Zeliha
on Jun 13, 2007 at 9:52:17 pm
Hi Everybody
I am trying to export a 4:3 quicktime file to DVC PRO HD 720P 60 codec. When I do this, the picture comes all streched. Is there a setting in compressor that will take the 4.3 image and maybe pillarbox it to retain the correct ratio of hte picture.
Many thanks.
Zee.
Peterd
Re: pillarboxing 4:3 when exporting to 16.9
on Jun 20, 2007 at 2:30:40 pm
Your best bet may be to try to drop your image into a 16:9 DVCPRO Sequence in FCP then export that. It the sequence is tagged at 16:9 and your footage as 4:3 it should pillarbox it automatically. It will take plenty fo render time in FCP to do the sizing but it should work. Test with a small piece of footage first to be sure.
