dvd compression and framerate problem
Jelena
on Jun 10, 2007 at 3:40:31 am
Hi everybody,
I have a slight problem I am trying to fix. I wasn't sure if it belonged in this group but its connected to compression, somewhat. Basically I am ripping tv shows from DVDs for a personal project and once they r ripped (i used two different programs) they come out great - full original quality mpeg2. Anyways, thats not the issue, once I import the files into After Effects or Premiere everything pretty much gets messed up, as in frames are skipping, its played out as if its recognizing upper field first even though lower field is what interpretation it is(and i tried every option), then it doesnt want to guess a 3:2 pulldown, so I tried manually, I tried rendering it at 24 frames and at 30, with pulldown, without pulldown...it just doesn't play well at all...
Any suggestions?
Shiloh
Re: dvd compression and framerate problem
on Jun 10, 2007 at 8:48:04 am
Ive had luck editing .VOB files in Premier by simply changing the file extension to .M2T and drag and dropping to a bin or timeline. .M2T = transport stream.
Shiloh
Jelena
on Jun 10, 2007 at 8:25:12 pm
hi,
that didnt work...:( premiere doesnt recognize it...
Jelena
on Jun 10, 2007 at 8:42:44 pm
so i installed the plugin and was able to open vod directly into premiere, but im still getting that jerking motion and major interlacing i cant get rid off....it still renders out the same no matter what option i pick
Jelena
on Jun 10, 2007 at 8:51:57 pm
AAAAA its fixed!!!! ThANX SHILOH, u rock!
Shiloh
on Jun 11, 2007 at 2:42:39 am
By the way some handy tools.
DVD Shrink 3.2 = FreeWare! (Some DVD encryption Require AnyDVD)
MPEG Sreamclip = FreeWare! (Good for converting, cutting and demuxing mpeg files without re-compressing)
AnyDVD (available through bit torrent)
Shiloh
Shiloh
on Jun 11, 2007 at 2:59:04 am
P.S. checked out your reels at your site. Verry nice work.
