File format for most used editting a effects sofware
Gabrielszi
on May 16, 2007 at 12:49:40 am
Hey there,
I am exporting some projects out of my After Effects and wanted them to be compatible with most of the video editting softwares, such as Premiere and Final Cut in both pc and mac. I was thinking of using QuickTime movie using PNG for the compression and RGB+Alpha, for transparency and to keep the file size low and still have a good quality. Is it going to work fine or is there any other format that I could use??
Thank you very much,
Gabriel.
Danny2007
Re: File format for most used editting a effects sofware
on May 17, 2007 at 10:04:03 am
You're certainly on the right lines heading down a Quicktime + PNG route. AVI can be a nightmare. Forget WMV.
