1440x1080i HDV to 720x480 MPEG-2
JCompton
on May 15, 2007 at 4:58:40 pm
I have a 1440 x 1080i HDV file in Final Cut Pro 5 that I want to
export as a 720x480 MPEG-2 file. I have Compressor and Compression Master. Should I simply export the FCP sequence to Compressor and
use it to make a 720x480 MPEG-2 file? Any help is greatly apreciated.
cadobee
Re: 1440x1080i HDV to 720x480 MPEG-2
on May 16, 2007 at 10:58:24 pm
there are many ways to do this, most of which i have recently tried,
and the simplest way to do it is to
>export to compressor
>chose dvd fastest encode (looks the same as best quality), all
>*important* double click your mpeg-2 entry under setting,
under the video format tab, set the field dominance to Bottom first.
>then if your taking it to dvd studio, change your preferences there also to bottom first.
another way is to export with quicktime to dvcprohd 720p, then to compressor normally. but the top way is faster.
-cade
JCompton
on May 18, 2007 at 4:58:18 pm
Worked like a charm. Thanks.
