Beta Sp to DV
todd mcmullen
Beta Sp to DV
on May 8, 2007 at 6:57:15 pm
I am attempting to archive and clone a large amount of Beta Sp tapes to the digital world.
(Approx 140 tapes)
Other than Digibeta, what would a good cost effective format be.
Obviously, the less compression the better. would DV cam be preferred over dvcpro 50?
I also need to keep the original timecode from the master.
Is there another format I am missing?
thanks
Todd McMullen
Flip Flop Films
Austin
http://www.toddmcmullen.com
Danny2007
Re: Beta Sp to DV
on May 9, 2007 at 10:24:50 am
Depends on what you'll be wanting to use the footage for. Personally I'd capture them to a high quality but efficient codec, usually one that will come with your capture card and leave them in just a digital form on some quality external drives.
No more tape, totally non-linear access, playout to whatever format you need...
Ed
Re: Beta Sp to DV
by
on May 11, 2007 at 4:10:34 pm
DVCPro-50 is much better than DV (CAM or otherwise). It's twice the data-rate. Photo J-PEG at 75% is pretty good too. We do some projects that originated on Beta in the DVCPro50 codec and it looks great.
Ed
Danny2007
Re: Beta Sp to DV
on May 11, 2007 at 4:47:16 pm
DVCPro50 uses a colour subsampling of 4:2:2, same as PhotoJPEG at 75%. PhotoJPEG at above 75% is 4:4:4, so much better.
Ed
Re: Beta Sp to DV
by
on May 11, 2007 at 4:55:31 pm
But 4:4:4 color sampling translates into huge file size, and it won't be any better
quality when you start with Beta-SP, which isn't 4:4:4. As an analog format it translates
roughly into 3:1:1. Putting it into a 4:4:4 color space doesn't do anything for the quality.
Ed
todd mcmullen
Re: Beta Sp to DV
on May 14, 2007 at 1:13:30 pm
What is a Formula for hard drive space ie...
1 30 minute betaSp digitized dvcpro50 equals ? gigs..
thanks
Todd McMullen
Flip Flop Films
Austin
Danny2007
Re: Beta Sp to DV
on May 14, 2007 at 1:46:49 pm
DVCPro50 is 50Mbits/second.
http://www.rorke.com/avcalc/calculator/RDAVStorageCalculator.swf
Be careful not to confuse bits and bytes (8 bits to each byte)
