Quicktime exporter is broken/slow all of a sudden
mozwald
on Apr 20, 2007 at 7:04:01 am
Ive been using quicktime exporter for easy fast h264 compressed videos. Usually 30second to 2min videos will render out to my seperate raid 0 scratch disk in about 30 seconds to a min, sometimes a little more.
All of a sudden the exporting is now horrible and slow...AND the video's it renders out arent even a real readable file by my PC, i cannot open any of them.
Ive tried exporting to AVI or other formats and its all the same speed no matter what codec I use. The first 8% instantly loads then it just drags.
Ive tried updating the software, but that didnt help...I have done nothing to change this.
What is going on?
Rich Rubasch
Re: Quicktime exporter is broken/slow all of a sudden
on Apr 20, 2007 at 5:42:31 pm
More info needed.....what platform? Have you updated ANY software recently?
Give us some system specs, including what kind of files you are using to encode etc. Frame rate/size.
Rich Rubasch
Tilt Media
mozwald
on Apr 20, 2007 at 5:47:58 pm
PC windows XP
No new software for the last month
Im exporting avi or mov files from premiere AND after effects, either compressed with a codec or no compression.
Ive tried opening and exporting older files that i know took only about 10 seconds to export from quicktime. No matter what codec i choose, or what file type i open up for exporting. They all jump to 8% then slow down.
The encoding time is the same no matter what settings i choose, ive tried exporting and mov, avi, mp4, etc, but its the same each time.
At first i thought it was my raid array, but i used mpegstreamclip and it was instant as opposed to 10x the time for quicktime (which it wasnt a few days ago)
Rich Rubasch
on Apr 20, 2007 at 7:21:07 pm
Coup0le things to try.....send the encoded clip to a different drive. Try changing a preference then changing it back. Kind of resets the prefs file. Try exporting to a different codec. If you have been exporting audio, try exporting video only.
Hmmm, that's all I have.
Rich Rubasch
Tilt Media
mozwald
on Apr 21, 2007 at 9:45:15 pm
just tried all those things, nothing fixed.
no matter what video, size, or codec im using it always jumps to 8% then becomes slower than mud.
I guess the only thing to do is uninstall and hope that it fixes itself to the original speed.
mozwald
on Apr 21, 2007 at 10:04:34 pm
uninstalled and still the same problems....the only thing that comes to mind that i have done differently is the installation of mpegstreamclip and capturing video with PP2.0
maybe one of those things messed it up...
