Audio with MPG2
dannunzio
Audio with MPG2
on Apr 9, 2007 at 2:45:42 pm
Hello,
I am exporting an MPG2 file using Compressor. How do I attach the audio to the MPG2 file so that they are together and not spereate. I can find any options in Compressor. I would like to have clients preview the file using quicktime over the internet, and now they have to play the audio seperate.
Mark
mmfarms
Re: Audio with MPG2
on Apr 9, 2007 at 7:28:38 pm
I found MPEG Streamclip that has worked really well for me...
http://www.squared5.com/
dannunzio
Re: Audio with MPG2
on Apr 10, 2007 at 1:52:38 pm
Thanks. I cannot export from FCP to this can I?
Mark
mmfarms
Re: Audio with MPG2
on Apr 10, 2007 at 2:39:40 pm
I've used it twice - specifically to add audio to mpeg2 for web video. I think you can export QT. You may have to export the video and then the audio. Keep the file names the same, with just their individual extensions, in the same folder. It's pretty simple to use - the help manual is excellent.
