Compression Error with Squeeze - Mac
bethshoe
on Apr 6, 2007 at 9:34:34 pm
I'm trying to compress several (relatively) small QT videos to FLV in Squeeze, and keep getting the same compression error once the file reaches 99% (it's a cruel joke). I found that for some of the videos, if I set the out point a couple of frames in, the compression works just fine. On others, nothing seems to help. I have compressed these same QT files to FLV before without issue, but they had slightly different settings. Are there any known bugs out there that is causing this? And more importantly, any known fixes?
The previous settings (without problem) are as follows:
Audio:
MP3 Codec
80 kbps
without a "normalize audio" filter
Video:
On2 VP6 Pro Codec
1-Pass CBR
700 kbps
Key frame every 60 frames
The current settings (with problem) are as follows:
Audio:
MP3 Codec
80 kbps
with a "normalize audio" filter
Video:
On2 VP6 Pro Codec
2-Pass VBR
700 kbps
Key frame every 30 frames
Craig Seeman
Re: Compression Error with Squeeze - Mac
on Apr 7, 2007 at 2:29:09 pm
What version Squeeze? 4.5.5 or 4.5.3, etc?
bethshoe
on Apr 7, 2007 at 11:55:10 pm
Version 4.3.3
Craig Seeman
on Apr 8, 2007 at 1:43:00 pm
Hmm, Download the trial for 4.5.5 and see if it happens there.
Did this issue just start happening?
You might consider deleting Squeeze and its preferences and reinstalling it.
I did use 4.3.3 and didn't see that issue (although I did see other issues).
bethshoe
on Apr 10, 2007 at 3:30:08 pm
I managed to fix the problem this weekend by setting BOTH in and out points for the clips in the squeeze "timeline" - now they're compressing fine. weird. must be just another glitch..
