Jagged Diagonal Lines
Scott Gray
on Feb 16, 2007 at 10:08:25 pm
I'm exhausted of running tests to try and produce a SD DVD that plays back a high resolution, static image with smooth diagonal lines in the image on an progressive scan display using a progressive scan DVD player. HELP!!! I've tried deinterlacing in FCP and every HQ progressive setting available in BitVice and Compressor 2. Every test looks the same, a roof line that is stair-stepping. Any ideas are greatly appreciated!
Ben Waggoner
Re: Jagged Diagonal Lines
on Feb 18, 2007 at 7:58:02 am
Can you post a screen shot of a frame showing the problem?
