Compressor preset export.
Scott Davis
on Feb 16, 2007 at 7:46:30 pm
Is there a way of saving a preset (not as a droplet) in Compressor to move to another machine?
Charles Simonson
Re: Compressor preset export.
on Feb 16, 2007 at 9:09:07 pm
Yep. Save your preset and then from the Finder, go to the Go command from the top menubar and select Go to Folder... and type in /Applications/Compressor/Contents/Resources/English.lproj/
Your settings should be in that folder.
Scott Davis
on Feb 16, 2007 at 10:04:55 pm
Thanks Charles, Weird thing is they werent there. I did find them in my user-application support-compressor folder.
Strange
Charles Simonson
on Feb 17, 2007 at 12:37:56 am
Yep, I would say that is weird. On my MBP at least, the settings in the directory you mentioned are all alias' to the ones in the Compressor application package. But I would think where you found them in your user folder would be a safer way of going about getting them.
