Save disabling Quicktime.
ben rollason
on Feb 14, 2007 at 1:04:11 pm
I used to use Cleaner to compress Quicktime movies. It had a feature that embedded a save disable inside the Quicktime itself (rather than using kioskmode=true which is easy to circumnavigate).
I'm now using Compressor and can't find any equivalent feature. Is there a way to achieve this in Compressor or exporting from Quicktime itself?
Thanks if you can help.
Ben.
Fink
http://www.fink-base.com
Charles Simonson
Re: Save disabling Quicktime.
on Feb 14, 2007 at 8:02:46 pm
You can do this after the movie has been encoded via scripting.
http://www.apple.com/applescript/quicktime/
