Authoring DVD... should I use Bottom Field First or Progressive?
rdomalpalli
on Jan 29, 2007 at 12:12:28 pm
Hi All,
I'm using Compressor to write Mpeg-2's for a DVD that will be watched on TV.
I was wondering whether I should use Progressive / Bottom Field First / Automatic for the Format Specification?
My input is Uncompressed 10Bit 4:2:2 1920x1080p Quicktime material.
I was told that I should use whatever the kind of TV is (progressive/ interlace). But I don't know what the end users will have...
Thanks in advance for your help.
Regards,
Rajnesh
Ben Waggoner
Re: Authoring DVD... should I use Bottom Field First or Progressive?
on Feb 18, 2007 at 8:04:10 am
What's the frame rate of your source?
If it's 30p, encode as interlaced.
If it's 24p, encode using Compressor's "24p" mode, which will make it have the proper 3:2 pulldown (top field first, I believe, but it doesn't really matter).
