compression settings on Squeeze
jack entonces
on Jan 23, 2007 at 8:30:54 pm
Hello,
I'm using Squeeze 3.5.
I want to compress a video from my Avid timeline to show on web.
Would like it to be no bigger than 20mb file size ...
I've done it before, but it's been so long that i forgot.
I start by exporting my timeline to a QT reference file.
Then open Squeeze and drag the QT ref file to it.
Then I don't remember what are the best settings ...
such as data rate, frames per sec, etc.
Can someone please tell me what are the best settings to
get a final quicktime web movie 20mb or less?
Thank you.
Reloaded
Re: compression settings on Squeeze
on Feb 1, 2007 at 1:40:16 pm
Well 20Mb. but what is the duration of your video?
About the frame rate, I don't recomend changhing it, leave it at 30fps.
You can reduce the resolution to 320x240 goog for the web.
About bit rate (the most important thing to reduce file size), your will have to cauculate it depending on the duration of your v
