Need help! Static problem with Compressor and MPEG 4
Peterd
on Dec 14, 2006 at 3:29:58 pm
k I'm trying to create so fairly small(about 10 meg) MPEG 4 files from clips between 30 sec - 2 min long. Right now I'm using compressor's MPEG 4 setting the current settings in compressor are:
320x240
1000 kbps
Frame control: Off
No Cropping
Pixel Aspect ratio default
There are currently no filters on the video in FCP. The source video is 8-Bit uncompressed. When i render the file sie comes out ok but there's alot of noise in the video especially when there's movement. Any ideas how I could set it up to get crisper looking video within these parameters?
