VOB to AVI using Sorenson Squeeze
paul
by
on Dec 6, 2006 at 7:08:56 pm
I have some DVD content that I need to re-task, although I don't have the source files. I noticed that the Sorenson Compression Suite will import a VOB (never knew that), although I'm not sure about the export format.
Does anyone have a suggestion on which export setting would be best for converting the assets (VOB to ?), editing in PPro, then re-exporting the finished product back to DVD?
Charles Simonson
Re: VOB to AVI using Sorenson Squeeze
on Dec 6, 2006 at 11:42:38 pm
For premiere pro, just export to QT using one of the BlackMagic codecs. Download the blackmagic codecs from decklink.com and you should be good to go. PP2 has better support for AVI, so you could use that as well if desired. But for PP 1 and 1.5., QT is the way to go.
