WMC Encoding on Mac system
bonnfox
on Nov 9, 2006 at 5:04:08 pm
I have 2-minute-long pretty simple videos that need to be encoded to wmv format for web streaming. What's the best way to encode for WMV on a Final Cut Pro system? Compressor or Cleaner or exporting as an avi and then encoding with the Windows Media Encoder? The streaming files shouldn't be bigger than 6MB. Any help is appreciated. Thanks!
Ed
Re: WMC Encoding on Mac system
by
on Nov 9, 2006 at 7:09:31 pm
Flip4Mac
Ed
bonnfox
on Nov 9, 2006 at 7:39:06 pm
Thanks for the response. I figured I had to buy that program.
Ed
by
on Nov 9, 2006 at 9:27:09 pm
And it will work right inside your QT apps, like Compressor, FCP, IMovie, QTPro, etc.
Ed
Charles Simonson
on Nov 10, 2006 at 6:03:47 am
The option of exporting a file first (preferably 10bit uncompressed) and then using a PC to encode will be much more efficient and give you many more options. That is, if going to a PC is an acceptable option for you. If not, then F4M is a fine choice.
Craig Seeman
on Nov 10, 2006 at 3:09:31 pm
and don't forget Episode as an option.
