bets way to convert .mp4 to Quicktime .mov file
rosindabow
on Oct 20, 2006 at 5:11:29 pm
I'm trying to convert an .mp4 file to a quicktime format that can be read by everyone, including those with Macs running OS9. What is the best conversion method out there? Any freeware available? Thanks.
Ed
Re: bets way to convert .mp4 to Quicktime .mov file
by
on Oct 20, 2006 at 8:32:26 pm
You don't say what platform you're on.
Ed
rosindabow
Re: best way to convert .mp4 to Quicktime .mov file
on Oct 26, 2006 at 5:10:43 am
Sorry,
I'm running a 2.5Ghz dual Mac with 6.5gigs of memory. Not sure which type of .mp4 it is but I belive it was based on using H264. Thanks.
Ed
by
on Oct 26, 2006 at 5:17:36 pm
FFMpegx: it's shareware and will do QT6 compatible files.
http://www.apple.com/downloads/macosx/video/ffmpegx.html
Compressor will too. Sorenson 3 is good. If you can get Sorenson 3 Pro, the files will look best.
Ed
Charles Simonson
on Oct 21, 2006 at 2:48:38 am
What type of .mp4 is it? If it is MPEG-4 Part 2, then that is compatible with QT 6 and OS 9. If it is H264 based, then you would need QT 7 for play back and need to convert. The codec I would recommend in that case is Sorenson Video 3. It is backwards compatible to QT 5.
