Compression for Camera Phones?
aaron sheddrick
on Oct 17, 2006 at 9:06:25 pm
How do you do it?
Ed
Re: Compression for Camera Phones?
by
on Oct 18, 2006 at 12:36:12 am
Use a compressor compress to 3G, 3G2, or MPEG-4
Ed
aaron sheddrick
on Oct 18, 2006 at 6:05:12 pm
I guess each company has their own specs. Does anyone have some sample specs I can test with on My Procoder 2 Station? Or is there somewhere I can look for example delivery specs. I just want to make sure I can deliver at these specs.
Mickey Power
on Oct 24, 2006 at 7:37:37 am
Here are some settings I'm using for a client:
Delivery Method Streaming Streaming N/A
Content Type MUSIC NON-MUSIC N/A
Target Bearer UMTS I/B 128 kbps UMTS I/B 128 kbps N/A
Total Bitrate 104 104 kbps
Rate Control CBR CBR N/A
Video codec MPEG4 VSP 0b MPEG4 VSP 0b N/A
Video Bitrate 80 92 kbps
Frame Rate 12.5 or 15 * 12.5 or 15 * fps
Key Frame Interval 3 3 seconds
Screen Resolution 176x144 176x144 pixels
Use Video Packets (NOTE 2) NO NO N/A
HEC (NOTE 2) NO NO N/A
Data Partitionin (NOTE 2) YES YES N/A
RVLC (NOTE 2) YES YES N/A
Audio codec AAC AMR-NB N/A
Audio Bitrate 24 12.2 kbps
AMR DTX - NO N/A
Use Joint Stereo NO - N/A
Automatic Audio Bandwidth NO - N/A
AAC sampling rate 22.05 - kHz
Hint Track YES* YES* N/A
Optimize for Progressive Download NO NO N/A
Maximum Packet Size 1400 1400 bytes
Export File Type .3gp [NOT .3gp2] .3gp [NOT .3gp2] N/A
For download, the total bitrate can be cranked up to 128.
Good luck
Mickey
Mickey
aaron sheddrick
on Oct 24, 2006 at 8:37:11 pm
Mickey,
Thank you so Much!
That's a lot of specs! Many of which I havent seen before! What software application are you using?
Are there any one can recommend?
Thanks a million!
daniel_l
on Oct 25, 2006 at 6:50:03 pm
The easiest is probably to upgrade to QuickTime Pro. QT Pro has some presets specifically for this, it's not the highest quality, that comes from a package like Xenon - http://www.vidiator.com/products/xenonEncoder.asp.
Many encoding applications rely on Quicktime for .3gp encoding. Xenon has it's own .3gp engine.
Mickey Power
on Oct 31, 2006 at 1:14:13 pm
Coming straight out of FCP 5. I think the 3gp encoder comes with it because I can't recall installing it separately.
I tried encoding with other programs but the results were no better than from FCP.
Best of luck!
Mickey
Mickey
