Codec Error
Pete
Codec Error
by
on Sep 3, 2006 at 10:14:57 pm
Hey guys i just got a clip from a potential client, and is some basic ovies that they want me to tweak, do some animations etx... but when i open is white, obvious codec missing, but never heard of this one; wheni open in quicktime (the file is an AVI) under format it says
720x480, millions, 16-bit integer (Little Endian), Stereo, 48.000 khz
what is ithis, thanks.
Charles Simonson
Re: Codec Error
on Sep 4, 2006 at 8:56:11 am
Most likely, it is an 8bit YUV uncompressed movie in either YUY2 or UYVY format. The only mac application that I know of to support this is Compression Master (as of 4.0.1 due to my requests). You could use CM to convert it to another format that you can work with, or you can get the client to provide you with an RGB or v210 (10bit) AVI.
