funky compression request
Michael Black FCP
on Sep 2, 2006 at 7:15:57 pm
Got these specs from a client. My first thought was, "We can do that." but then I sort of remembered MPEG-2 maxing out at 9 Mbps. Is this compression even possible?
Video files must be encoded to the following specification:
MPEG-2
GOP Pattern: I Frames only
Image Size: 720x480 NTSC
Pixel Aspect Ratio: Square pixels (VGA)
Frame Rate: 29.97fps
Bit Rate: 20 mbps (20000 kbps)
Bit Rate Control: Constant bit rate
Quality/speed: Highest Quality
Deinterlace
Charles Simonson
Re: funky compression request
on Sep 3, 2006 at 3:58:28 am
Yes. This can be done if your encoding app supports it. MainConcept, ProCoder, and Compression Master support this. Cleaner, Compressor, BitVice, and Squeeze do not.
