Editing on Mac FCP 5, Encoding and Authoring on PC-----HELP PLEASE
zvi4343
on Jun 28, 2006 at 6:53:04 pm
I am looking for validated and efficient ways to take
media cut on FCP 5 and compress it on a PC. I prefer
to encode using a PC as Compressor, although easy to
navigate, runs like a sick dog on my PowerBook G4.
Currently, I am exporting my sequence from FCP using
QT Export w/the following settings:
Frame Size 720x480 NTSC DV (3:2)
Pixel Aspect Ratio NTSC-CCIR 601 / DV (720x480)
Field Dominance: Lower
29.97fps
QT Video Settings/Compressor: DV/DVCPRO - NTSC
(quality 100%)
Audio 48k; 16bit; stereo mix
File size and playback on Mac seem good at this point.
I am then encoding using Autodesk Cleaner to make
.mov, .wmv, and elementary files. This is where the
breakdown occurs with these files. Autodesk Cleaner
has no trouble doing the same encodes to files that
originate on a PC when using AvidXpress.
So the question is this...am I dealing with some sort
of Mac/PC incompatibility? Or is it something else.
Anyone have a solution or thoughts.
Thanks in advance.
daniel_l
Re: Editing on Mac FCP 5, Encoding and Authoring on PC-----HELP PLEASE
on Jun 29, 2006 at 9:14:32 am
What 'breakdown' are you experiencing with cleaner?
DL
Video AllSorts
Charles Simonson
on Jul 3, 2006 at 9:41:05 pm
I wonder if some codec of filter is installed on your system that is incorrectly taking over the decoding of your movie?
