Cleaner 6.5 and On2 VP6 Codec
John Fishback
on Jun 9, 2006 at 3:57:45 pm
I have Flash 8 Encoder which encodes using the On2 VP6 codec. However, the encoder offers no way to apply filters. I was playing around with Cleaner 6.5 and was able to use the On2 codec and apply filters. The resulting flvs looked much better than Flash encoder. However, when I encode with Cleaner, I lose the Flash encoder's ability to insert cue points in the flv. Does anyone know how to retain the cue point functionality using Cleaner? And the other question might be how to use filters in Flash encoder.
John
Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
Dual Cinema 23 Radeon 9800
FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
Huge U-320R 1TB Raid 3 firmware ENG15.BIN
ATTO UL4D driver 3.50
AJA IO driver 2.1 firmware v23-28
SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
Rich Rubasch
Re: Cleaner 6.5 and On2 VP6 Codec
on Jun 10, 2006 at 2:08:58 am
This is a similar issue using an encoder like Bitvice and not getting the markers that you would if you used compressor...sometimes it's a trade off.
Don't have an answer about using filters in Flash...are they filters you can apply with cleaner first, then run the result through the flash encoder?
Rich Rubasch
Tilt Media
Craig Seeman
on Jun 20, 2006 at 2:15:40 pm
Squeeze 4.3 can also use On2 VP6 but I'm not sure if that'll solve your problem. It may be worth it to contact Sorenson though.
John Fishback
on Jun 20, 2006 at 2:36:17 pm
I have Squeese 4.3 for Flash, but it doesn't come with the VP6 codec. I was hoping to avoid the additional cost of the On2 codec since I had Cleaner which did the filtering well and fast. Looks like I'll have to bite the bullet and purchase the codec.
Thanks for the advice.
John
