MPEG-1 in Cleaner 6.5
cowcowcow
ScottieB
on May 22, 2006 at 4:35:42 pm
I have been asked to make an MPEG-1 out of a movie file for "universal" playback. Basically, I need the file to be layable on as many computers as possible, and have been asked to make an MPEG-1. I am trying to make a new preset in Cleaner for this, but have a question that I can't seem to find the anser to - even in the manual. In the output section of the settings window, I am asked to choose a "Stream Type" - the choices are elementary or system. I need the audio to be muxed together with the video in an MPEG-1. It is my understanding from the DVD world and MPEG-2 that an elementary stream is video only and that a program stream is a .vob - muxed audio and video... but this particular choice escapes me. What should I choose here for highest compatibility? Thanks,
ScottieB
Rich Rubasch
Re: MPEG-1 in Cleaner 6.5...answer
on May 23, 2006 at 1:19:03 am
How to get Multiplexed files when encoding as mpeg-1 or mpeg-2
Solution
When encoding with Cleaner as an mpeg-1 or mpeg-2 clip,
you may end-up with two separate files.
ex: One Video file ( .mpg ) and one Audio file ( .wav ).
You may want to have those files multiplexed (this is also known as muxed).
In order to do so, follow this simple routine.
1- Go in the advance settings.
2- Select your mpeg-1 or mpeg-2 setting.
3- Select the Output tab.
In mpeg-1: From the Format pull-down menu
4- Uncheck Video CD Compatible
5- Then follow step # 6.
In mgeg-2: From the Format pull-down menu
4- Change mpeg-2 for any other codec.
5- Then bring it back to mpeg-2.
You will see Stream Type.
6- Choose Elementary if you want separate files
Or Program / System if you want them Multiplexed.
Rich Rubasch
Tilt Media
Ed
by
on May 23, 2006 at 2:11:32 pm
Maybe even more important is, did they fix MPEG1s in Cleaner 6.5? I'm not sure, but I doubt it.
Cleaner did a terrible job of MPEG1.
Ed
