Image shifts down when button pressed on dvd. Encoding settings? Fields?
cowcowcow
pforson81
on May 12, 2006 at 11:18:41 am
Ive made a dvd using mpegs encoded in compressor 2. On all the menus when the user selects an option to either go to another menu or play a track the screen pauses and the image appears to shift down, before changing.
It looks like a fields issue with the mpegs (this does not show up when viewed on a computer only on a tv) Its very noticable with the text. The top line of the text vanishes and a bottom line appears.
It doesn't seem to be an authoring issue, could it be some encoding settings in compressor?
Any help hugely appreciated as I urgently need this fixed.
Thanks very much
Pete.
