h264 field issue
Rob Tinworth
h264 field issue
on Apr 20, 2006 at 10:36:17 pm
Getting some great results from the h264 codec, but notice that it is getting field order mixed up pretty regularly (with both upper and lower dominant source material). This can be fixed by switching the field order over from automatic to custom (I'm using Compressor), but this results in render times that make you weep (you know it's bad when you get in the next day and it's STILL rendering).
Anyone come across this field issue and worked out a better way of dealing with it?
Rob
Rob Tinworth
http://www.1021.tv
Ben Waggoner
Re: h264 field issue
on Apr 26, 2006 at 4:17:31 am
Apple's H.264 implementation doesn't support fields - it's progressive only.
Rob Tinworth
on Apr 26, 2006 at 12:48:53 pm
So does that mean that I need to deinterlace any interlaced material before I encode?
Rob Tinworth
http://www.1021.tv
Ben Waggoner
on May 4, 2006 at 5:11:42 am
Yes, if you're using Apple's H.264.
