compressing a music video
Aria Slade
on Apr 5, 2006 at 5:35:21 am
using a Mac, I edited a music video in and exported from Adobe Premiere, then exported from Adobe After Effects to convert it to .avi format.
unfortunately, to upload the video onto a website, it must be under 100 MB - but the file is around 540 MB.
how can I compress this?
Ben Waggoner
Re: compressing a music video
on Apr 5, 2006 at 6:17:27 am
If you've got the final edit in Premiere Pro, you can use Adobe Media Encoder to make a .WMV file. For download, use 2-pass VBR. How long is the video? 50 MB should be enough for decent quality if it isn't too long.
Aria Slade
on Apr 5, 2006 at 10:02:55 am
the video is 3:40 long, thanks!
Aria Slade
on Apr 9, 2006 at 9:07:34 am
is there any way to do this using Adobe After Effects? Because I'm having trouble finding the Media Encoder for Mac anywhere.
daniel_l
on Apr 11, 2006 at 11:04:52 am
Ideally you need one of the following applications to produce a decent quality compressed version - AfterEffects won't do the job for you.
Sorenson Squeeze
PopWire Compression master
Autodesk cleaner
Apple Compressor
FFMPEG
DL
Video AllSorts
