What's the best solution for an MPEG2 encoding from a ref file?
thewanggao
on Mar 20, 2006 at 10:42:01 pm
Out of fcp, I have exported a reference file. Would you suggest that Squeeze, Compressor, or Cleaner will give me the best MPEG2 compression?
Alexander Gao
"When the revolution happens, I'll be leading it."
Ed
Re: What's the best solution for an MPEG2 encoding from a ref file?
by
on Mar 21, 2006 at 4:11:50 pm
I can answer part of the question, DON'T USE CLEANER! It's not a good MPEG-2 compressor.
Ed
Claireystew
on Apr 3, 2006 at 2:03:51 am
I haven't used Squeeze in a while, but between Cleaner and Compressor, Compressor was by far the better result, as long as you can live with the limitations it imposes on the MPEG2 file.
