compressor and a dvd with bad motion flow
macmauro
on Mar 2, 2006 at 10:15:46 pm
Hi from Maurizio, italy, pal system
i edited a video Final Cut 4
it's full of still images and then video clips
on an original soundtrack
i compressed it with compressor and made a dvd using dvd studio pro
then the problem:
at the beginning the sound follows
images in the way it has to
but during a sequence of very fast still images (1 for second)
the music is on late, it start later then the video clip and goes on in this wrong way
i can't say it's a lost of synchro
cause at the end of the video
the music return to be ok.
i tried different compression setting (60 min. 90 min. 120 min. on dvd) and different motion estimation but i didn't solve the problem
is it a special case using rapid sequence of images and then
normal frame rate for mpeg2 compression?
what kind of setting i could try?
any suggestions?
thanks
Maurizio
