MPEG 2
edwige_7
MPEG 2
on Feb 24, 2006 at 10:41:22 am
I try to find a tool to export files in MPEG 2 from final cot pro. The problem is I have to encode specific size of movie (like 896x896 or 1248x624).
Autodesk cleaner XL make only standard size, compressor also. It has to be in a MPEG2.
Thanks for helping,
Laurence
Charles Simonson
Re: MPEG 2
on Feb 24, 2006 at 9:10:33 pm
MainConcept, Squeeze, ProCoder, Compression Master, Digigami, ffmpegX, all should allow you to export at your desired size.
Ed
Re: MPEG 2
by
on Feb 25, 2006 at 5:00:23 pm
All good encoders. You may have trouble exporting from FCP with Procoder though (PC only) :-)
Ed
[edwige_7] "I try to find a tool to export files in MPEG 2 from final cot pro. The problem is I have to encode specific size of movie (like 896x896 or 1248x624).
Autodesk cleaner XL make only standard size, compressor also. It has to be in a MPEG2. "
