How do I compress to a .wav file? Or am I only able to with quicktimes .mov format?
Clint Nitkiewicz Hern
on Feb 21, 2006 at 9:09:06 pm
I need to use compressor from final cut pro, to compress a movie into .wav format for the web, as opposed to the .mov's normally used format? any converters out there, for the mac??
thanks a lot
Charles Simonson
Re: How do I compress to a .wav file? Or am I only able to with quicktimes .mov format?
on Feb 22, 2006 at 7:52:00 pm
QT Pro will allow you to export directly to a WAV audio file. QT Pro also has an option for .AVI if that would help.
Gregg
on Mar 19, 2006 at 3:24:29 am
You can export .WAV directly out of FCP without using compressor. It is one of the options when you Export to Qiucktime. I don't have the program in front of me right now so I can't guide you to it, but the option is there. I have used it.
