Question for Ben...if you're still around
Barlow Elton
on Feb 14, 2006 at 9:51:07 pm
Hi Ben,
I'm trying to convert 1080i DVCPRO HD (recorded live from Canon XL-H1 to Kona SDI card) into DVCPRO 60p, and then convert to DVCPRO 24p for a true slo-mo look.
A person in the HDV forum said you recommend Compressor for this chore. Is this correct? I'm rendering out a 5 sec. clip and it's amazingly slow on my G5 dual 2.7...I checked a bunch of motion adaptive stuff in the frame controls area of the inspector, which is why I think the render is going slowly.
Any insights you could share?
Barlow
daniel_l
Re: Question for Ben...if you're still around
on Feb 15, 2006 at 1:47:17 pm
Although I'm obviously not Ben and therefore not qualified to answer this question, you might want to check this out while you are waiting for him to respond.
http://www.creativecow.net/articles/solorio_marco/twixtor_review/index.html
Barlow Elton
on Feb 16, 2006 at 7:49:26 am
Hey, thanks for that link.
btw, I did figure out how to do the conversion. It looks amazing, and the slow motion is amazingly smooth too.
Ben Waggoner
on Feb 21, 2006 at 7:45:57 pm
Sorry, I'm on paternity leave this month, so not checking the boards as much as usual.
Glad it worked for you. The optical image flow stuff is amazing, albeit amazingly slow...
