Mpeg2 to flash using VP6 in Squeeze
untruehero
on Feb 10, 2006 at 6:25:18 pm
We recently purchased the on2 pluggin for squeeze 4.3 and we aren't having much luck. For a 12 minute clip it took over 5 1/2 hours to turn the program into flash at 460x360 2 pass vbr, total rate rate of 700. Using almost the same settings on squeeze to make a QT file from the same Mpeg 2 it only takes 30min. As anyone else had problems with VP6 from on2 in squeeze?
Charles Simonson
Re: Mpeg2 to flash using VP6 in Squeeze
on Feb 11, 2006 at 3:50:59 am
VP6 is slow, very slow. It is also only single processor aware, so the speeds you are experiencing are normal. Of note, I have encoded some content with VP6, and while the quality was very good, it took 60x on a 2.6GHz Dual (not that it mattered) Opteron (HD Source).
untruehero
on Feb 13, 2006 at 2:46:34 pm
Thanks for getting back to me Charles. I have been doing some testing with on2's Flix Pro Demo and that program has been a little bit faster. However I am not completely satisfied with the quality. Have you had any experience with this program?
Thanks again,
Scott
