Compression settings for the web...example of my work inside
DVX100Shooter
on Feb 5, 2006 at 9:41:43 pm
I am new to Creative Cow!
Below is a link to a EPK I just produced for a client. I used Compressor to compress the footage but I know I can get it to look a lot cleaner for the web than it does now. Its super clean on DVD though.
Any suggestion as to what I might try differently in terms of settings would be cool. I used FCP HD to edit and export.
Chuck
http://www.youtube.com/w/?v=ThtUbi3mJNU
Ed
Re: Compression settings for the web...example of my work inside
by
on Feb 6, 2006 at 7:08:51 pm
Hard to say what you might try differently in terms of settings when you don't say what your settings were.
Ed
[DVX100Shooter] "Any suggestion as to what I might try differently in terms of settings would be cool. I used FCP HD to edit and export.
DVX100Shooter
on Feb 6, 2006 at 10:15:16 pm
I didnt write the settings down...Is there a way I can pull up that info from the compressed file? One complaint I have been hearing is that my current settings take so long to play back and when it does playback it breaks up.
Ed
by
on Feb 6, 2006 at 10:31:54 pm
I'm a bit confused. You used Compressor to compress the footage, then what? It's a Flash movie, did you compress
it in Compressor, then compress it again to Flash? If so, you took a hit in resolution. Again, if so, why didn't you use
something like Squeeze to create an FLV directly from the uncompressed edited file?
Ed
[DVX100Shooter] "I used Compressor to compress the footage but I know I can get it to look a lot cleaner for the web than it does now."
