Last frame URL link to CM encoded Quicktime?
twistlick
on Feb 2, 2006 at 2:43:54 pm
I use Compression Master 3.2.2 to make .mov files using the MP4 & aac codecs. I have to add a URL link to the last frame of the movie. The only solution I know of to do this (on Macintosh) is with Cleaner but I don't like Cleaner's MP4 results. Can I do my compression in CM then run it through Cleaner 6 (or 6.5 if necessary) WITHOUT RECOMPRESSING but just adding a URL link to the last frame? If so, how? Is there another way to do this?
I want the last frame of each of the Quicktimes on this site to link to the home page if somebody clicks on it:
http://www.dogblogtv.com
