HD uncompressed to MPEG 2 via Compressor rendering times
Dale Launer
on Jan 31, 2006 at 6:17:10 am
I have a movie - 1:45 (an hour 45 min), and when I do a two pass VBR crunch via Compressor - it takes about 36 hours to work it's magic. This is with a G5 2 x 2.5ghz and 2 gigs of RAM.
I'm using a AJA KONA Vuy codec (originally they were Cinewave YUV files).
Is a day a half too long?
I have another G5 - a 2x 2ghz - if I connect these via Qmaster - anyone know approximately how much improvement I would see?
Dale
Ben Waggoner
Re: HD uncompressed to MPEG 2 via Compressor rendering times
on Feb 9, 2006 at 7:46:58 am
The big problem with QMaster is that your VBR gets worse the more nodes you have, since it does each VBR on each node independently.
