UH-OH. . . MPEG-2's giving me some trouble.
thewanggao
on Jan 17, 2006 at 8:46:26 pm
I shot some test footage in 16:9 progressive on a sony DCR-TRV900. Now, I know it's truly only 15fps, but when i export using compressor to MPEG-2, the video looks terrible, nothing compared to what it was in the timeline. It looks kind of like if i set the timeline to half quality. What am I doing wrong? When i export to animation quicktime, it looks just fine.
- My target output is DVD (MPEG-2 needed first, of course). I shot it at 15fps progressive because I am using a DCR-TRV900 and the progressive mode gives much better image quality, but it only records 15fps and then doubles all of the frames to simulate 30 frames.
- I am using compressor because i want to end up with an MPEG-2 to burn onto a dvd in dvdsp 4. I chose this route because I thought i kne what i was doing, but honestly have never worked in prog. mode before.
- My backup plan was to come too creativecow in case I ran into trouble.
Ok, so do you have any suggestions for me as to why my output is getting so poor in qulaity when i go from fcp straight to compressor, and why it looks GREAT in the timeline, but horrible as MPEG-2??? (My settings in compressor were 90 min best DVD, 16:9, and this loss of quality occurs no matter what dominant field I choose. Bottom, top, progressive, OR automatic).
Alexander Gao
"When the revolution happens, I'll be leading it."
Charles Simonson
Re: UH-OH. . . MPEG-2's giving me some trouble.
on Jan 18, 2006 at 5:18:35 am
Could you post a test file some where for us to take a look at? I don't have any experience with the camera or mode you are talking about, so its hard to know where to begin with your issue.
thewanggao
on Jan 19, 2006 at 1:30:35 am
gladly. i'll post the link once i find a place to upload it.
Alexander Gao
thewanggao
on Jan 19, 2006 at 2:00:36 am
Charles: Thanks for all the help, but I solved my problem! I just trashed fcp prefs and it looked great after tat. Thanks though!
Alexander Gao
thewanggao
on Jan 19, 2006 at 2:01:49 am
By the way: I just wanted to commend you: Creativecow needs more users like you, who help people when no one else seems to be able to answer the question.
Alexander Gao
Priscilla Brasil
on Feb 16, 2006 at 1:38:17 am
Dear Alexander,
I've got the same problem of yours... You've said u found a solution for it. Can you post it?
Thanks so much,
Priscilla
